AOLIN car alarm systems
Hi all. So just doing a little tidy up under the dash of my 2 gen2. i found this old car alarm and a lot of bad wiring/splicing. in an ideal world id like to remove it.
its a white box "Aolin car alarm systems" on the front. i'm 99% sure it doesn't work if anyone had a diagram or even install instructions for something like this that would be helpful.
Thank you
Thank you
- IMG_1553.png (313.01 KiB) Viewed 209 times
- Has thanked: 78 times
- Been thanked: 157 times
Re: AOLIN car alarm systems
I suspect you struggle to find anything on that Chinese system. You'll probably have to trace the wires from it back to the original car wiring and find out how it interfaces with the cars systems
ok i have made some progress in tracing back the wires, ill begin with removing the sound actuator. and remove the associated Relays
Keep trying the car as you disconnect things, that way it's easy to backtrack if it won't start
- Has thanked: 42 times
- Been thanked: 21 times
not sure if this is the correct model
https://www.the12volt.com/installbay/fo ... ?tid=62215
