Brake caliper painting
Topic author - Posts: 2
Hi All,
Looking for a little help and advice please.
I am stripping and rebuilding the brake calipers on my Red, and whilst doing so decided to go all boy racer and paint the calipers.
I have heard that the high temperature caliper paint is a little bit of a con, and decided just to use Hammerite but have heard this may fade over time, but research shows a few in favour of Rustoleum, has anyone any experience of this and can help in any way please?.
- Years of MR2 Ownership: 14
Re: Brake caliper painting
I have used "proper" Caliper paint, also used smooth hammerite and finally also used heat resistant paint.
Caliper paint tends to be tacky for ages but finally cures to be a longish lasting cover.
Hammerite covers well, cures quickly but does fade over time then starts to flake.
Heat resistant paint worked pretty good.
now if I was rebuilding capliers and leaving for a week before fitting I would use the Caliper paint every time.
if its a quick on the car clean up its a toss up between the other 2.
Hope that helps
Hope that helps
- Real Name: Alan Byrne
- Been thanked: 32 times
The problem with caliper paint is that it is really thin. So you need lots of thin coats. I did mine a couple of years ago and its started to fade and show rust. But I am picking my spare set of calipers up from the powder coaters today. I would recommend having them powder coated. Then rebuild them. I did a short thread on stripping a full set of Mk2 brakes. Just been waiting to get them coated so I can do the rebuild. I’ll show you the finish later.
Here my calipers back from powder coating. Will rebuild then this week sometime and finish my other thread off. But at least you can see the finish and it only cost me £50 to get them cleaned,blasted and coated. A tin of paint is about £20 nowadays. Then all the prep work etc.
- IMG_3838.jpeg (102.11 KiB) Viewed 300 times
- IMG_3837.jpeg (92.33 KiB) Viewed 300 times
- IMG_3836.jpeg (122.55 KiB) Viewed 300 times
