Cam seal removal
DanboneT
Cam seal removal
Post by DanboneT »
Hi all new to mr2
I’m part way through sorting an oil leak I’ve dropped the engine. Set timing and removed belts cam pullys ect. Do I have to remove valve cover and cam end bearing caps to remove cam seals or can I pull them out without removing valve cover and end caps
Many thanks Dan
Has thanked: 50 times
Been thanked: 130 times
Re: Cam seal removal
I think you have to remove the cover, the BGB has info on refitting the camshaft seals, page EG1–108 of the 1993 SW20 Repair Manual (download it here https://mr2oc.co.uk/downloads/technical-stuff/mk2.html) it's referring to the 3S-GTE but I'd suspect the 3S-GE is the same
benckj
Years of MR2 Ownership: 5
Been thanked: 4 times
Post by benckj »
Can simply drill a hole in outer lip, install a self tapping screw and pull out with seal with pliers. Obvious need to be careful not to damage seal seat when doing. Can use old seal to cover replacement when tapping into place with hammer.
DanboneT
Post by DanboneT »
Hi sorry for delay in reply. I managed to do what benckj said and drill and pull them. Another question should the 2 arrows align with each other on oil pump
benckj
Post by benckj »
TBH I don’t think it matters as they rotate anyway. I searched on this subject when I replaced my oil pump seals and never found out what arrows were for. Installed it as found and never had an issue.
DanboneT
Post by DanboneT »
benckj wrote: 14/07/24 19:23 TBH I don’t think it matters as they rotate anyway. I searched on this subject when I replaced my oil pump seals and never found out what arrows were for. Installed it as found and never had an issue.
Thanks had a Quick Look online someone said to aline them so I did. Will say it almost looks like it wouldn’t matter it almost lines up or fits in a certain position
