Coilover or standard
Use this forum to chat about general MR2 topics. See also the Mk1 Mk2 and Mk3 sections above for more specific technical information
The forum Administrator has chosen to advise you that this topic is 1 year and 8 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
[email protected]
Post by [email protected] »
Hi, not a tech question on suspension- more a general request for advice on the merits (or not) to fit coilovers to a MR2 based on your experience. I am restoring a U.K. spec MR2 MK2 rev2. Next phase (and almost last phase) is the suspension- i’m having the underside sealed and having the suspension removed to do it. I now have a choice- fit coilovers or fit as close to original as possible - excepting Original dampers may now be discontinued. I love this car… I will never race or use it on a track. I would be glad for some general viewpoints on what you would do based on experience. Thank you…
_Al_
Years of MR2 Ownership: 15
MR2's Owned: 7
Real Name: Mr Misfire
Has thanked: 150 times
Been thanked: 29 times
Re: Coilover or standard
Post by _Al_ »
Coilovers or not isn’t a binary option. The difference between a cheap set and a quality set isn’t just branding - you get a much more capable set of equipment. There’s also the question of supporting mods like roll centre adjustment etc. if you’re just doing it for road I’d stay as close to stock as possible
Red 92 tintop JDM 3S-GTE
Blue 95 tintop JDM 3S-GTE
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
jeff
Years of MR2 Ownership: 20
Real Name: Jeff
Has thanked: 42 times
Been thanked: 21 times
Post by jeff »
i found original springs were impossible to source, so went for coil overs and really happy with ride
nick
Been thanked: 4 times
Post by nick »
I agree re coil overs. Better handling and no worse ride. If you go on track the adjustability is a bonus.
You need to get proper suspension alignment done .
BYRNEY1984
Real Name: Alan Byrne
Been thanked: 33 times
Post by BYRNEY1984 »
I fitted tein fully adjustable coil overs when I restored my rev1 bodywork. They are perfect for the road and set at a nice nice for speed bumps etc. even though I have a genuine bomex front bumper which is lower and longer. Clears the humps fine when slow of course. Also I removed the whole suspension set up and polybushed everything including the engine mounts and had it all powder coated. Looks amazing when it MOT time haha. Just don’t get cheap coil overs or you hate the ride and same as cheap polybushes. Its a bit dirty as I have just almosty finished refitting my V6 turbo after stripping that for powdercoating
PirateMR2
Post by PirateMR2 »
I had to put new suspension on my rev2 lat November the handling had got a bit unpredictable. I was daily driving it and regularly doing 150 miles In a day. I found that fitting all new stock was just just to expensive. Went with BC coil-overs with the soft springs they offer. Transformed the car. Ride is still pretty decent agree with others on here about not going to low. I set mine to to sensible level based on the factory measurement to the suspension. Did 6000 miles in it over the winter no corrosion showing on the coil overs but I do coat them up every now and then with some ACF50. Rock solid in all weathers. Kept the standard bushes. Fitted new Toyo tyres in stock size. All the claims about lairy handling are because they are worn out or non std wheel sizes. Been out in it today and it still feels great. I am now dailying a new Gr86 so it not like I don’t know any better. I am near sSouthampton if your close your welcome to have a go.
Would love to drive a stock car with all new suspension and bushes mind to see what it’s like. Not sure such a thing exists mind.
peteV6R5
Years of MR2 Ownership: 14
Real Name: Pete
Has thanked: 2 times
Been thanked: 12 times
Post by peteV6R5 »
If you can get standard struts (or the ones you have are good) then Apex springs are a very good option.
30mm lower with progressive springing, good ride but firm up when pushing on.
My 1st suspension mod. (along with all suspension and roll bar bushes etc)
BC coilovers are the better choice good ride but much better handling when pushing on.
my 2nd suspension mod .
MotoMarx
Post by MotoMarx »
My car is a MK3, but for what its worth, I had standard dampers with Tein springs, one of the springs fractured so needed replacing and when I looked the dampers were pretty crusty. In the end I went for Tein Flex Z and they are not much firmer to be honest. I also fitted Whiteline ARBs, they make a huge difference to body roll, so I'd recommend them too.
Return to “MR2 Discussion”
