Ignition barrel
DanboneT
Ignition barrel
Post by DanboneT »
Hi have mr2 rev2 1993 ignition barrel has tumbler problem as can’t turn key it will turn if I tap I key with a hammer so at least I can remove barrel. So need to replace it is proving difficult to find one for sale, so I noticed a similar age celica barrel looks the same does anyone know if that or other Toyota barrels would fit
Has thanked: 77 times
Been thanked: 153 times
Re: Ignition barrel
According to the EPC they are MR2 specific and can vary from Rev to Rev.
Any use ?
https://www.ebay.co.uk/itm/374790524138 ... pQQAvD_BwE
https://www.ebay.co.uk/itm/296509894944 ... R6icgfqiZA
BYRNEY1984
Real Name: Alan Byrne
Been thanked: 32 times
Re: Ignition barrel
Post by BYRNEY1984 »
If it helps. I fitted a full set of locks from a uk rev 3 i to my jdm rev 1. Because the door key was different from the ignition. They all fitted fine.
DanboneT
Re: Ignition barrel
Post by DanboneT »
Thanks. I feel that earlier models are the same. It’s finding the part and some other Toyotas in those years might fit so gives me a better chance of finding the part I’m after it’s if anyone knows what other models will work
_Al_
Years of MR2 Ownership: 15
MR2's Owned: 7
Real Name: Mr Misfire
Has thanked: 148 times
Been thanked: 29 times
Re: Ignition barrel
Post by _Al_ »
I’d contact a breaker like J-Spec, they may well have what you need.
Red 92 tintop JDM 3S-GTE
Blue 95 tintop JDM 3S-GTE
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
BYRNEY1984
Re: Ignition barrel
Some is selling a set in ebay for £70. All locks and complete ignition barrel. Just no glove box lock and the cubby box behind the drivers seat.
Re: Ignition barrel
The 2 links I posted above are for locks for sale ;)
