Rain causing weak spark/not starting?
Had to leave the car sitting outside past week and was driving it everyday, went out on Sunday morning and car wouldn't start. Was cranking fine but no sound of it starting.
I was out in the car Saturday night and has been running great since getting it back on the road a few weeks ago.
Took the leads off and put a screwdriver up the lead and was weak spark to the block.
With the heavy rain and bank holiday cleared out the garage and left it inside for a few nights to dry out before buying parts.
Car started fine tonight and spark from the leads is strong again so guessing rain or damp got in with the storm we've been having.
Having a look around the coil and distributor cap don't have shrouds over them so thinking water got in from the passenger side engine lit vent and got in some how or something else got damp causing weak spark.
I didn't pull the cap off on Sunday when I put it in the garage but pulled it off this evening to have a look and it was dry which makes senee since it started after.
Anyone have any similar issues?
If any sort of shroids are available? I'm assuming it was the coil or distributor cap.
I know the proper answer is keep it garaged but was grand past 2 weeks and In this climate you can never trust the weather, really wouldn't want it happening away from home lol
- Real Name: Patrick
Re: Rain causing weak spark/not starting?
Hi Gavin, I had similar symptoms to you. I changed the coil and that solved the problem.
- Has thanked: 150 times
- Been thanked: 29 times
ECU capacitor aging may exacerbate the failure, but I’m voting coil as well. They can crack with age and let moisture in.
Red 92 tintop JDM 3S-GTE
Blue 95 tintop JDM 3S-GTE
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
Sorry forgot to get back.
Yeah seems it was the coil. Put a plastic bag over the coil pack under the fuse box and haven't had any issues.
Bit hooky but works as a proof of concept
I'll put a new one in at some stage aha
- Has thanked: 78 times
- Been thanked: 157 times
Good enough to diagnose the problem, lets you use the car and gives you time to find and fit a replacement. Nothing wrong with that
