Suspension knocks driving me bonkers
adenbakker
Years of MR2 Ownership: 1
Real Name: Andrew den Bakker
Post by adenbakker »
When driving over uneven surfaces, knocks and clunking sounds emanate from somewhere under the car (1993 rev 2). I’ve had the car on the lift for inspection a few time, but cannot find anything suspicious, apart from possibly some rotational play in the trailing arms where the bushings seem a bit soft (not damaged). The arms can be rotated with light manual effort and come to ‘hard stop’ with a bit of an audible knock. (Video available, but I haven’t found a way of uploading this)
Not sure however if this could cause the fairly severe and frequent sounds. The steering and handling is OK. Car has new droplinks, new bc racing coilovers; all other bushings look OK.
Any ideas if this is a known issue, or any other suggestions what could cause (suspension) knocks?
All suggestions are welcome!
Thanks, Andrew
_Al_
Years of MR2 Ownership: 15
MR2's Owned: 7
Real Name: Mr Misfire
Has thanked: 148 times
Been thanked: 29 times
Re: Suspension knocks driving me bonkers
Post by _Al_ »
Balljoints or top mounts? Both can “look ok” but be worn beyond use
Red 92 tintop JDM 3S-GTE
Blue 95 tintop JDM 3S-GTE
Mica 96 T-bar UK
Red 96 UK
Sonic Shadow 98 2GR
jeff
Years of MR2 Ownership: 20
Real Name: Jeff
Has thanked: 41 times
Been thanked: 21 times
Post by jeff »
adenbakker wrote: 22/06/24 9:05 (Video available, but I haven’t found a way of uploading this)
if its on YouTube just paste in the url
