Hand Brake Cable Part Numbers
Topic author - Posts: 93
Hi All,
Trying to source two rear hand brake cables for my MK2. Been given two OEM numbers 4643017050 and 4642017050. I have a couple of questions, firstly are both cables identical so can I use the same one on either side and are the numbers supplied correct for my car, which is a rev1, march 1991.
Any info appreciated.
Darren
Darren
- Been thanked: 31 times
Re: Hand Brake Cable Part Numbers
The Toyota EPC has those two part numbers listed for the entire production run of Mk2 MR2s.
https://toyota-europe.epc-data.com/mr2/ ... 601/46420/
https://toyota-europe.epc-data.com/mr2/ ... 601/46430/
The fact that the numbers are different suggests they are not 100% identical and are handed (i.e. L/R).
- Has thanked: 33 times
try tcb
www.tcbparts.co.uk
www.tcbparts.co.uk
From TCB's site.
Hand Brake Cable
MR2 Mk2 SW20 (1989 -1992)
Part number: J16268
Price: £25.00 + vat each cable
Hand Brake Cable
Part number: J16277
When ordering, ask Paul which side the numbers refer to. The page doesn't say.
Hand Brake Cable
Part number: J16268
Hand Brake Cable
Part number: J16277
- Has thanked: 48 times
- Been thanked: 121 times
IIRC the difference is in the brackets attached to each cable. If the cables were the same there would be only one number. Mr T uses the same part number for identical parts across all the model ranges.
There's a "How To" in KY2 for fitting https://mr2oc.co.uk/know-your-2/mk2/mk2 ... cable.html
