Are mk2 abs control units 'coded'?
tom_lowery
Topic author - Posts: 3
my local garage said they could only fit a new abs control unit if it doesn't require 'coding'. idk what they mean by that, and I also couldn't find any more info about it online, so I was hoping someone here might know.
any thoughts or ideas would be greatly appreciated! thanks in advance.
Snorkie
- Real Name: Paul
Re: Are mk2 abs control units 'coded'?
Hi.
If you can find a ABS control unit it is plug and play (does not need coding to car).
