Battery not charging.
Topic author - Posts: 17
Put on all external lights as engine was running to check them and battery lost power.
I know there are 2 fuses in the front. The 7.5 I checked and is ok. The bigger fuse not sure how to take out, can it just be pulled out? Is there a 3rd fuse. As you can see from photos the battery stay around 12v and does not go any higher to suggest its being charged by alternator. If I was to try and put the multimeter up to the alternator (tight squeeze) if it was working okay would I see 12v with the engine off? This is the last job "hopefully" before I take it for a mot. Help appreciated
Re: Battery not charging.
Try the checks in this article to test the alternator https://www.mr2oc.co.uk/know-your2/mk2/ ... ad-on.html
MK2'svare prone to alternator wiring problems, depending on the test results this article may also help https://www.mr2oc.co.uk/know-your2/mk2/ ... epair.html
Thanks Jim. Do you think its more likely it could be a fault in the loom? If I can get to the 3 pin plug then I will test each one. Other than that I was thinking of taking alternator out and repairing it.
- Has thanked: 33 times
i would suggest doing the above checks otherwise you're just guessing as to whether its a faulty loom
As Jeff says, the point of the tests is to find out if it's a wiring fault or alternator fault, without the tests your just guessing. Follow the article exactly, post up the results if your not sure how to interpret them.
Can see a little bit of corrosion at the bottom of alternator on 2 bolts.
- Screenshot_20210503-075941_Gallery.jpg (32.18 KiB) Viewed 102 times
thats great, but what was the results of the tests ?
All fuses are good. Main bolt going into alternator as good, over 12v. Tried from underneath to get 3 pin plug out but it's just out of reach. Now trying from above but can't get a good grip on it to remove it!! Taking a little brake then will try again. Was thinking if I can't then remove the alternator!
Got the 3 pin plug off. Now it won't sit back in snug! Is it meant to click into place?
Get over 12v from each pin.
If your getting full battery voltage at the pins it would indicate a possible alternator problem. Don't remember the plug clicking in place but they are usually tight.
What condition is the battery in ? How old is it ?
That white deposit looks like waterproof grease, if it's soft and wipes off that's what it will be quite common electrical connectors in MR2 engine bays
Battery is new. In the process of removing the main bolt holding the alternator to the bracket but limited space to do it. Gave a spray with wd40! Hopefully will help to loosen the bolt. Want to repair alternator myself.
You should find a pretty big write up on here on how to repair it yourself.
The main thing besides the bearings and brushes is to replace the Diode pack.
That's not good it should be 14v plus when car running..12v means faulty alternator or voltage regulator.
The 12v was with the engine off, he was following a test procedure to try and eliminate either the alt or the wiring
