Engine lid fans
Topic author - Posts: 73
- Real Name: Andy
- Has thanked: 3 times
Engine lid fans
Has anyone had these/experience of these? I know the 2’s engine bay gets silly hot and was wondering if there is any real benefit from having them?
- 68508617-6D81-48AE-9A20-4A9C9E50F9F4.jpeg (116.71 KiB) Viewed 58 times
Re: Engine lid fans
Had a single in my tubby lid on the V6 not that setup, these fans have big power drain, close to 8 amps each, so that needs to be taken into consideration with battery and available alternator power output.
saying that my single would pull summer bay temps in traffic from 45c down to 38c pretty quick
Re: Engine lid fans
Personally I went to a single fan.
If you get the right size and profile fan you can simply sandwich it between the hood and the stock rain tray with no screws or fasteners required, its far tidier in appearance and the water is still going where its supposed to. Do it right with tidy wiring in that flexible black conduit and it looks better than stock.
Also the current draw starts to climb and it may not simply be a question of tapping the power for it from the existing side mount inter cooler fan. You also want them to still be automatically temperate controlled so this is the logical take off point because you do not want them to be running all the time because the noise is frankly annoying.
I also upgraded the stock intercooler fan at the same time so the current draw went through the roof. Took a new 30Amp fused feed from the engine bay fuse box and used the stock Fan ECU relay to drive a spare power steering relay that's good for like 60 Amps to drive both fans. My hood fan is just a cheapie but the IC fan is a SPAL so the combined current would be like 20 Amps when they kick in. Made an additional box of electronics for mine so not only do they both kick in with temperature but they kick in when the boost goes over 5psi.
You have to remember that this puts some significant intermittent additional load on the alternator so you better have one that's been rebuilt with a set of new rectifier diodes and brushes in it.
