Hardtop leak
Robbie.G
Topic author - Posts: 3
Hardtop leak
I bought my hard top in December and had it fitted by the guy selling it, it was fine for a couple of weeks until I went to put some beer in the storage compartment behide the seats and found a fair bit of water back there but only on the drivers side.
I took the hardtop off dried everything (soft top, storage space and hardtop) and re-fitted the hardtop adjusting the clamps so they were tighter and making sure they were properly alighned.
It's been a week later and we've had 3 days of bad rain so I checked today to see if more water has leaked through.....and it has, same again only on the drivers side.
I Would really appreciate anyones input or idea on what could be causing the leak
Cheers.
Cheers.
jeff
- Has thanked: 42 times
- Been thanked: 21 times
Re: Hardtop leak
block drainage pipes ?
Robbie.G
Re: Hardtop leak
I've checked the tops of the pipes both look clean and were only cleaned out a few weeks ago, but I guess it's worth having a look again
Robbie.G
Re: Hardtop leak
It seems to be leaking around the edge of the hardtop
- 20210130_112057.jpg (40.65 KiB) Viewed 336 times
