How do I tell which engine
The forum Administrator has chosen to advise you that this topic is 3 years and 6 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
rae finlayson
Been thanked: 1 time
Post by rae finlayson »
I have a Mk2 rev2 turbo. How can I tell which engine is fitted, if it is the 227hp, 234hp or 241hp
MR2Jay
MR2's Owned: 7
Real Name: Jay
Been thanked: 8 times
Re: How do I tell which engine
Post by MR2Jay »
OK, easiest thing to do is post a pic of the engine for us to identify...
Thisng to look for?
On early engines there is an AFM behind the air filter, this is a big silver lump. Also check the rocker cover. If "Toyota" is stamped on this, then it's an early engine. Later 3S-GTE engines also had an Oil catch can suspended above the rocker cover....
peteV6R5
Years of MR2 Ownership: 14
Real Name: Pete
Has thanked: 2 times
Been thanked: 13 times
Post by peteV6R5 »
https://mr2oc.co.uk/know-your-2/mk2/mk2 ... -bays.html
know your 2 (KY2) is your friend
AFAIK rev1-2 were 220 BHP standard
rev3+ were 240 BHP standard
rae finlayson
Thanks for the reply mr2jay. There is no Toyota stamped on the rocker cover. Here's a couple of pics.
rae finlayson
Pete I have looked through KY2 but can't find anything
peteV6R5
Real Name: Pete
Post by peteV6R5 »
rae finlayson wrote: 07/11/22 14:47 Pete I have looked through KY2 but can't find anything
link in thread will take you there to item
dansrev2turbo
Years of MR2 Ownership: 5
Post by dansrev2turbo »
It's a Revision 2 engine, 220bhp.
rae finlayson
Sorry peteV6R5 missed the link
Thanks very much dansrev2turbo
