Ignition problems
Topic author - Posts: 15
- MR2's Owned: 0
- Real Name: Andy Horn
Ignition problems
Hi all.
We seem to have a problem with the ignition, we changed the engine oil as it looked a bit gloopy, all good on that front.
Once we built up the oil pressure we fired the engine up and all was good again.
However after letting it cool down to check oil level, we started it again and after a couple of minutes it will simply stopped and wouldn't start again.
We took a spark plug out and tested for a spark, result no spark.
After an internet search it's looking like the problem could be the coil igniter, which are difficult to find.
I have not had chance to run a diagnostic test to prove it though.
Has anyone experienced this particular issue and if there is way to repair the igniter or replace it with one of a different car igniter.
Occasionally in the past it has randomly cut out, but usually it would start again after a couple of attempts.
Thanks in advance Andy
Re: Ignition problems
have you checked for error codes ? https://www.mr2oc.co.uk/know-your-2/mk1 ... kbartid=61
- MR2's Owned: 0
- MR2's Owned: 0
Having checked the error codes it appears we have a none working coil igniter, however it starts.
Any ideas?
Cheers
Any ideas?
Cheers
- MR2's Owned: 0
I got 3 flashing lights which so far as I know indicates a problem with the igniter, ignition circuit or the ECU according to this https://www.mr2oc.co.uk/know-your-2.htm ... kbartid=61
After further investigation, since the engine failed to start, the distributor and rotor arm have seen better days.
Once I have replaced these parts I'll report back with my findings.
Merry Christmas
Merry Christmas
