KYB NEW SR SPECIALS? Worth much?
iLogik
Messing around with the car earlier taking photos of the repair/mod work done to front bumper and noticed the shocks were New SR specials Kyb jobbies.
Are these standard on a mk3 or they aftermarket and if so they worth much?
bossman23780
Re: KYB NEW SR SPECIALS? Worth much?
I gather youre having issues with rubbing because of the car being lowered plus a body kit? if you still want your 2, have you considered having the tein adjustable kit, then you can adjust the ride height.
iLogik
I get scrap-age just wondering if the shocks on it at the mo are worth much. Was toying with the idea of replacing the advans with some 17 split rims. With bigger tyres, should lift it up a bit more.
bossman23780
Well you could put bigger tyres on but then raise the chance of tyre rubbing and throw your speedometer out but after seeing youre car i think the cause of rubbing isnt the aftermarket shocks or springs but the body kit, PM loadswine on ROC, he has a similar style kit to yours, i'd ask him how he finds his car for rubbing.
iLogik
he finds it the same, had the underside cut off it like he did, only thing left is bigger wheels like his got. But even then multistore car parks are impossible.bossman23780 wrote:Well you could put bigger tyres on but then raise the chance of tyre rubbing and throw your speedometer out but after seeing youre car i think the cause of rubbing isnt the aftermarket shocks or springs but the body kit, PM loadswine on ROC, he has a similar style kit to yours, i'd ask him how he finds his car for rubbing.
