luke warm heating
The forum Administrator has chosen to advise you that this topic is 4 years and 4 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
harri46
luke warm heating
Post by harri46 »
Hi All.
I have a mk2 1991, and have been having problems with the heater on the car for a while. Heater blows 'lukewarm air' and as you get to the third and fourth fan speed's it becomes virtually cold. I have a new radiator, waterpump, and have changed the radiator cap. Have been advised it might be the thermostat, but there isnt much movement in the temp guage ranging from half way up to about quarter of an inch lower so not sure about that.
There's no leaks, and the radiator is topped up.I had it running with the radiator off to get rid of any air in the
system which has improved it slightly, but its still not right.
Be grateful for any advice.
Darren
SonicSW20
Been thanked: 6 times
Re: luke warm heating
Post by SonicSW20 »
Have you confirmed that sliding the heat control is actually fully adjusting the valve? Have you also confirmed that you actually have flow through the matrix?
Does the car get up to operating temperature (middle of the gauge or just below) and stay there with little deviation?
harri46
Post by harri46 »
Hi.
Wouldnt know how to test the heat control/valve or the flow through the matrix.
Once up to operating temperature, the gauge stays about half way or goes down about quarter of inch below.
Is that deviation enough to require a new thermostat?
peteV6R5
Real Name: Pete
Has thanked: 2 times
Been thanked: 11 times
Post by peteV6R5 »
deviation sounds like you have air in the system
did you bleed with heater open fully
also there is a bleed screw on the heater inlet in frunk
Has thanked: 45 times
Been thanked: 120 times
https://www.mr2oc.co.uk/know-your-2.htm ... bartid=161
This KY2 article covers bleeding the cooling system, from about section 25 onwards ;)
harri46
Post by harri46 »
Thanks for the replies and info. Looks like a new thermostat aint gonna fix it then. Will look into getting air out of the system.
Cheers
Darren
