MK3 Engine prob - coolant
A Friend of mine called me up hoping i could help him out with an issue
He done a water pump change on his car and installed a new therostate.
Problem is he said the coolant isnt going round the engine properly (not sure if i heard him right)
Has anyone had this problem before?
- MR2's Owned: 10
- Real Name: Mick
Re: MK3 Engine prob - coolant
You must have an air block somewhere you will need to bleed the system properly.RSTsteve wrote:A Friend of mine called me up hoping i could help him out with an issue
- Real Name: Ken
Or the thermostat (sp) is not working correctly.topgun wrote:You must have an air block somewhere you will need to bleed the system properly.RSTsteve wrote:A Friend of mine called me up hoping i could help him out with an issue
Get your friend to sign up here
