mk3 specs
mk3 specs
hi all,just wanting a few specs for the mk3 as its something im considering for a project car.
wheel specs-pcd and offset of the early spec 15's and the later spec 15/16 combo.
brake disc weights if anyone knows.
whats the weight distribution of the car?
where is the fuel tank located?
is the radiator in the front then piped to the block along the central tunnel.
anyone done a fixed roof before?
any cages available for the mk3?
sorry for the randomness of the questions.
basically any shell up build pics would be appreciated too(links etc)
cheers
cheers
Re: mk3 specs
Welcome to the club
Someone who knows somethign useful will be along shortly, i'm sure
4x100... that's about all I know about mkIIIscrashtestdummy wrote:wheel specs-pcd
Re: mk3 specs
Take alook on IMOC for Rogue and check MR2ROC for lots more info on the MK3 MR2.crashtestdummy wrote: wheel specs-pcd and offset of the early spec 15's and the later spec 15/16 combo. Offset 45+ alround regardless of year, 15 x 6JJ front, 15 x 6.5 rear (Later spec 16x7JJ rear)
brake disc weights if anyone knows. Know Idea
whats the weight distribution of the car? 44/56
where is the fuel tank located? Behind the seats, below the the rear compartments
is the radiator in the front then piped to the block along the central tunnel. Yep
anyone done a fixed roof before? Rogue Motorsport Can probably help you
any cages available for the mk3? Search for Rogue Motorsport, they make a cage for the MK3
Re: mk3 specs
one answer Ilogik is probably your best bet look at the threads i am sure some might help
