Mystery Rattle when in Gear
Hey all, i have tried searching for this specific issue but came up with nothing.
I have a 1991 MR2 T bar that has developed an odd rattling noise. At first it sounded like a valve issue or lack of oil but I have just changed the oil and know its good. I'm pretty certain its not the engine too as so far I have managed to pin it to the following:
Only does it in gear
Only does it between 2-3500 RPM
Only does it if I keep the revs constant, accelerating through the range is OK
Sounds to be coming from either driver side or centre console area
My local garage has had a look but found nothing as it doesn't do it when standing still.
I'm just wondering if anyone has had similar before if they know of any heat shields that may be causing this because its horrifically noisy when it does it and very annoying.
Other things that may be of interest is that 2nd gear likes to crunch sometimes and it ran itself dry of clutch fluid 6 months ago
Any help would be awesome cheers!
