Radio Wire Mess
Topic author - Posts: 4
Radio Wire Mess
Hi lads,
The Rev2 has been without a radio for quite some time. Hoping someone can help me identify the wires coming from the void that used to contain a radio. Hopefully a new radio will be able to get fitted with what's here.
- Real Name: Brian
- Has thanked: 5 times
- Been thanked: 5 times
Re: Radio Wire Mess
errr thats a bit of a "Job" do they go back to a ISO plug? in the depths
like this this one is actually one MR2 Ben sells this connects to the factory plug & allows to fit a head unit of your choice with cutting anything hopefully the previous haven't
- thumb_PC2-17-4.jpg (4.9 KiB) Viewed 47 times
"That's a Negative Jim..I Do Not Have The Measles!"
Re: Radio Wire Mess
Only the pink/blue & black/red are original, all the rest (including the led) look like "replacements" what for and where they go is anyones guess. The adapter Brian has posted is Toyota to ISO, but I doubt there's one in there, the pink/blue & black/red wires would originally have attached to the Toyota connector.
At a guess someone has "rewired" the speakers etc other than starting again, your going to have to trace the cables to see where they go.
Re: Radio Wire Mess
That's your worst nightmare when you try and put a new radio in. As stated above, pull those cable out as far as you can, might be worth taking the whole surround off to get a better look then get a plug bought to go into one of those adapters. I was lucky and mine had the original cassette deck with everything stock, literally plugged in a connector from mr2 ben and off I went.
Let me know if you need a picture of what wires you need, sure it's online but sometimes they're hard to find.
Re: Radio Wire Mess
Personally I've never found Know Your 2 difficult to find .... It's on the menu at the top of every forum page
Re: Radio Wire Mess
Not to mention
https://www.mr2oc.co.uk/know-your2/mk2/ ... lours.html
https://www.mr2oc.co.uk/know-your2/mk2/ ... ystem.html
https://www.mr2oc.co.uk/know-your2/mk2/ ... agram.html
Also Workshop Manuals & Electrical Diagrams to download here https://www.mr2oc.co.uk/download-cats/c ... 1-mk2.html
And of course there's the ICE forum https://www.mr2oc.co.uk/forum/43.html
