S54 5th Gear Overdrive
The forum Administrator has chosen to advise you that this topic is 3 years and 6 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
webb2800
Post by webb2800 »
I've got a fairly straightforward question regarding the S54 transmission. On a UK model 3S-GE, is 5th gear considered an overdrive gear? (as in a gear with a ratio less than 1:1, or meaning 4th gear would achieve a higher top speed)
BYRNEY1984
Real Name: Alan Byrne
Been thanked: 33 times
Re: S54 5th Gear Overdrive
Post by BYRNEY1984 »
webb2800 wrote: 24/11/22 5:42 I've got a fairly straightforward question regarding the S54 transmission. On a UK model 3S-GE, is 5th gear considered an overdrive gear? (as in a gear with a ratio less than 1:1, or meaning 4th gear would achieve a higher top speed)
I believe these are the gear ratios for the S54 box
3.285 1.960 1.322 1.028 0.820 Diff: 3.944
Hope this helps
nick
Been thanked: 4 times
Post by nick »
As the car will not pull anything near peak revs in 5th, I would call it an overdrive, like most moderns. The gearing is arguably odd, as it is slightly faster in 5th than 4th.
webb2800
Post by webb2800 »
yeah, looking at those ratios Byrney gave is interesting. Plugging them into a calculator gives ~127mph top speed in 4th and ~159mph in 5th (Standard wheel/tyre height, 7250 rpm). I'd be suprised at a standard n/a hitting 140. In real terms 5th is only getting you that final 10-15mph when talking purely top speeds.
So, not technically an overdrive but certainly fuctions as one in any practical capacity.
Tallboy
Years of MR2 Ownership: 19
Real Name: Dave
Has thanked: 12 times
Been thanked: 15 times
Post by Tallboy »
nick wrote: 24/11/22 12:19 As the car will not pull anything near peak revs in 5th
i beg to differ it will it just takes time to get there, im talking rev 3 na
MK2 REV3 NA R.I.P
MK2 REV3 95 TURBO Reborn!!!..... now in Dawesys hands getting 2GR love
MK2 REV4 NA R.I.P
MK2 REV3 96 TURBO
MK2 REV3 NA AUTO Reborn!!...... Now in Mikes hands getting boosted!
