throttle body
throttle body
Hi can someone help me I have a rev 3 na 94/95 import I have had a small problem with the idle going up and down on the od occasion then it is fine been meaning to sort this for awhile what I want to know is can I use the throttle body of a uk rev5 na with sensors on my car and if so is this an easy thing to do and is there a gasket that would need done at same time cheers.
Re: throttle body
not really looked at the difference between rev3 and rev5 TB's.stu pot wrote:Hi can someone help me I have a rev 3 na 94/95 import I have had a small problem with the idle going up and down on the od occasion then it is fine been meaning to sort this for awhile what I want to know is can I use the throttle body of a uk rev5 na with sensors on my car and if so is this an easy thing to do and is there a gasket that would need done at same time cheers.
The erratic idle is usually:
1) air leak somewhere on vac pipes or inlet side
or
2) ICV idle control valve that needs cleaning.
- Real Name: Stu
Re: throttle body
I agree with Pete. Worth cleaning the entire throttle body & ISCV.
Have a read here: Poor-Idle-When-Cold---Rev3-N-A-**-Almost-Fixed**
http://mr2oc.co.uk/ocforum/viewtopic.php?t=141257
Re: throttle body
Cheers guys I just had a look at that view topic and that looks easy enough to do so will give it a go thanks for the reply's.
Re: throttle body
Rev 4 and 5 tb is different to rev3.
I had one. I'd take a pic but had all my spare parts thrown out
Usually icv needs a clean. If you have a/c the idle up valve goes faulty
