Head gasket / water pump
The forum Administrator has chosen to advise you that this topic is 4 years and 3 weeks old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
spooky771
Post by spooky771 »
Hi Guys
Ive been having abit of a water leak which it looks like its from the water pump,
Ive also noticed that ive got white mix in my filler cap ( but nothing in the oil or on dip stick )
which im sure that means head gasket?
so looks like a big job of doing water pump and head gasket and which means new timing belt?
To do all this would this be easier to drop engine to do it all ?
any suggestions would be nice
thx
Snorkie
Years of MR2 Ownership: 1
Real Name: Paul
Been thanked: 1 time
Re: Head gasket / water pump
Post by Snorkie »
White mix (looks like mayonnaise) under the oil filler cap is normally caused by condensation. If there is nothing in the oil or on the dip stick its probably caused by short runs or the engine not getting hot enough.
Without seeing pictures its impossible to say where leak is coming from. If it is the water pump it can be replaced without taking the engine out. Yes you would have to remove the timing belt at the same time, so may as well replace that as well.
FirstMidship
Post by FirstMidship »
If you do decide to take the water pump off, the right hand engine mounting bracket is very awkward, I still havent got mine in yet, also, use an impact gun on the top right hand philips screw on the water pump, or the head will be chewed up.
Toyota MR2 MK2 Rev 5 NA (1999)
