Sst 09843-18020
StoneyMR2
Topic author - Posts: 35
- Years of MR2 Ownership: 2
- Real Name: Rob Stone
Sst 09843-18020
Hi all. Looking through the BGB on fault finding and keep coming across this Sst 09843-18020 tool. Is it worth buying one, or can it be made? Also, how exactly does it work?
Thanks.
Thanks.
MR2DI4
Re: Sst 09843-18020
Yes its called a short piece of wire.
I actually crimped a couple of those narrow male connectors on the ends of it so it was a perfect fit into the diagnostic box female connectors, but essentially people use a bit of wire or a paper clip.
All you are doing is shorting the two correct test points together. The ECU detects the short and throws the fault codes that are stored in it up on the engine check light.
StoneyMR2
Re: Sst 09843-18020
So it is just a piece of wire? No LED or anything? Am I right in thinking you then just cross reference the blinks on the dash with the codes in the BGB?
MR2DI4
Re: Sst 09843-18020
Correct.StoneyMR2 wrote: 16/11/22 21:00 So it is just a piece of wire? No LED or anything? Am I right in thinking you then just cross reference the blinks on the dash with the codes in the BGB?
- Has thanked: 98 times
- Been thanked: 171 times
StoneyMR2
