Warm starting problems
The forum Administrator has chosen to advise you that this topic is 4 years and 3 months old and that you may wish to begin a new topic or use the search feature to find a similar but newer topic.
chrisowen57
Post by chrisowen57 »
My 2001 Mk3 always starts first time when cold or hot but needs two or three attempts when warm. I recently changed the coolant temp sensor and the plugs and injectors are all new. I've also cleaned the MAF sensor. I noticed it started to happen after I changed the injectors. It runs perfectly once it starts. Any ideas?
Return to “MK3”
